240 Strange noise
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
This topic is in the MVS Volvo Repair Database » Volvo To Hybridize Entire Line
markvt
240 Strange noise
Post by markvt »
1992, 240 with approx 195 K miles. I replaced the shocks and struts a few weeks ago. After 200-300 miles a noise apprearing in the front (passenger side). Not sure if it's related to the strut replacement or not. After the replacement everything was quiet for the first 200-300 miles.
Noise sounds like it's definitely something in the front suspension. I hear a tapping noise when I go over even the smallest bump. It sounds like plastic. I thought for sure the underside pan was loose, but I had it on a lift today and checked and shook everything I could and found nothing loose.
The only thing I didn't do was put a bar under the front wheels and check the ball joints (will do that tomorrow). Any other thoughts on what could cause the noise? I did recheck all of the installation points of the struts and everything is as it should be.
Mark
1992 240 GL
1966 Sunbeam Tiger
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
You didn't leave an assistant under there, did you?
Check the ball joints as you may have disturbed something when you did the suspension job causing it to fail.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
markvt
Post by markvt »
"You didn't leave an assistant under there, did you?"
No, but I wondered if I left a tool in the plastic tray because that's what it sounded like. Unfortunately...no tool was found:-)
I will check the ball joints if the weather will warm up here. In the meantime think I will drive the pick-up.
Mark
1992 240 GL
1966 Sunbeam Tiger
