Volvo 940 1991 headlights
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
tonyheywood
Post by tonyheywood »
When selecting main beam headlights both headlights go out, and the headlight flasher doesn't work! Since everyything on the associated fuses still works, the flasher/dip switch appears to "click" correctly and its unlikely that both bulbs will have gone simultaneously, ANY IDEAS?
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Have you checked the bulbs?
The headlight fuses only cover the headlights so nothing else should be affected if the fuses go. Check them as well.
There is a relay in the fuse/relay panel at position K which is front row, 2nd from the left. If the bulbs and fuses check out give the relay a sharp tap to see if it 'kick starts' it.
Post back with your findings.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
