So last time I checked the oil, I didn't replace the distick all the way and had been getting awful fumes in the cabin. So i opened it up with the engine running and saw a little smoke or steam coming out of the dipstick tube. I thought it was just from the fumes being so hot on the freezing day. It had been like that for about 3k miles, and sat in the freezing cold for about 6 days while I was in Florida.
Anything to be worried about? Car is fine now, no milky oil or anything.
Smoky Dipstick?
895meztz94
- Year and Model:
1999 Volvo V70 2.4 Base 207k miles and counting
2003 Saab 9-5 Linear
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
If the engine compartment isn't covered with oil I would say you have done no harm.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
hammertime
- Year and Model: '04 XC90, '07 XC70
- Has thanked: 1 time
Sounds like the problem I now have with my '96 850. Positive crankcase presure from a clogged up PCV system. I have ordered a new system and will be replacing it soon. Search "PCV" for more posts on the subject.
'04 XC90
'07 XC70
Zamboni Model 545 (my work vehicle)
Prev. '68 142, '96 850 GLT Sportswagon, '98 V70 AWD, '98 S70 T5, '00 V70 XC
first car ever owned: '74 BMW 2002tii
'07 XC70
895meztz94
- Year and Model:
That's good, I've heard the smoke is indicative of the PCV needing replacement.
chuckcintron
- Year and Model:
Tim, that is unusual. There should be a slightly negative pressure at the dipstick -- assuming your rings are good. Does the smoke go away or get worse with higher engine RPM?
-Chuck
-Chuck
1997 855GLT
895meztz94
- Year and Model:
Anyone know if this kit will fit? It only lists up to 1998 models.
I absolutely cannot find a 99+ kit.
http://cgi.ebay.com/ebaymotors...ories
- Has thanked: 17 times
- Been thanked: 35 times
Unfortunately, I've not seen a '99 and newer PCV kit....I would buy every part here: http://www.eeuroparts.com/Main/PartsResults.aspx including at least 4 feet of the vacuum hose (for good measure) and replace one part at a time. Make sure and cleand the PTC valve thoroughly as well as the small ducts from the oil separator into the hose- if coked on, ream everything out until the passages are clear. While eveything is off of the manifold, clean the throttle body and as well.
- 2033 Views
Last post by Ben850
- 3062 Views
Last post by boksalg
- 4111 Views
Last post by PapaNoni
- 5071 Views
Last post by JimBee
- 791 Views
Last post by Ludermilch
