I have fault code 323 in bank A1. That corresponds to "lock up slips or is not engaged"
What can I do to fix this?
Fault Code 323 Bank A1
- Has thanked: 2660 times
- Been thanked: 1248 times
ABS sensors clean? I've never read about that code, but it hints at a wheelspeed mismatch error, no?
- Tsquared
- Year and Model: 11 C30
- Has thanked: 1 time
potroast,
You are correct with the Socket A1 being the transmission. The code "323 Lock up slips or is not engaged" relates to the "locking" tourque converter.
First try a power flush of the transmission. You may have some debris keeping it from locking. This may flush it out.
The transmission is a weak point on our cars. It was designed to be a closed system requiring no periodic maintenance (fluid needs to be changed every 30 k per most mechanics I have talked to). There is not a filter in the trans. Typically the fluid braks down and that can cause various problems inside the trans. Other issues are the electronics inside the trans that can go out (I had solenoid problems).
Another issue is that there is no room to do a partial dis-assembly in the engine compartment or go through inspection covers (they have none). The trans must be removed for any type of service for parts. For that agrivation you will not want to do it more than once. I found that the rebuild price was not too far from a new trans from Volvo. I went with a new trans with a new tourque converter and I replaced the rear engine seal while we were there - keep in mind this is worst case and it may be corrected with a power flush. Do a search on transmissions...
Good luck
T
Good luck
T
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
the flashing lambda went away immidiately following a transmission flush.
I am hoping that this fixed it, and was it was not a mere coincidence. I am at 163,000 miles, and i can't remember it being flushed recently, so it was time, anyway.
- Tsquared
Good to hear that. I have a friend with a 95 GLT that flushes his every 15 k because of an "A1 321 Shift time too long" that will pop up when the fluid gets the slightest bit worn. He has been doing this for about 90K. I tried flushing 3 times before I gave in and replaced my trans with a new unit. You can also add a trans cooler for less than $75 that will also help prolong the trans fluid life (I have found a $65 kit at NAPA that splices in with-out much trouble that I plan to add when I service the trans in about 10K).potroast wrote:I am hoping that this fixed it, and was it was not a mere coincidence. I am at 163,000 miles, and i can't remember it being flushed recently, so it was time, anyway.
Cheers,
T
'11 C30 T5
- 1190 Views
Last post by warmblood58
- 1258 Views
Last post by adventurer2112
