90 740 2.3.2 code.
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
jim234
Year and Model: 93 940 Turbo
90 740 2.3.2 code.
Post by jim234 »
I got one more for you Bill
I also own a 1990 740 Volvo. I have had this for a while. I went and replaced two vacuum hoses on this today. Started running better! The car, when idling will surge just a little bit, it's uneven. I went and checked the codes. This is what I got.
232 Adaptive lambda control too lean /rich when idling
Sounds similar to the other. Am I back at the oxygen sensors again? Any suggestions?
Jim
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Jim,
I was just going to congratulate you on a job well done then saw you've broken another car!!! :roll:
Congratulations on fixing the 940 for minimum outlay.
Code 2-3-2 on the 740 does not necessarily mean the oxygen sensor is gone. My book says to check the inlet manifold for leaks and to check the fuel pressure. It also goes on to give a check list which does need the CO2 reading to complete. I have been waiting to throw this list at someone and you qualify. High on the list you will see "check spark plugs replace if necessary". So this may not be too expensive to repair. (We don't have a smiley with crossed fingers).
740 code 2-3-2.pdf
(442.1 KiB) Downloaded 238 times
I am splitting this away from the thread as it does relate to a different, although similar, model.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
