Hi. I have a 2001 Volvo S60 and have a problem with fuel tank. Its very difficult to put gas into the car. I have to barely squeeze the lever and fill it up very slowly or the pump shuts off because the gas comes back up. No check engine light, nothing.
I have some skills, but I dont know much more about gas tanks, than how to replace a fuel pump. .
Help would be very appreciated..
2001 S60 - difficult to put gas into the car
First, the easiest: does it do it if you go to a different gas station? I had this trouble on a 1978 Chevy Monza after I slid into our school bus and put a big dent in it - must have crimped the fuel filler hose. Did you run into a school bus?trigon82 wrote:I have to barely squeeze the lever and fill it up very slowly or the pump shuts off because the gas comes back up.
Wildman
2001 S60 2.4T @110K Miles
- Has thanked: 17 times
- Been thanked: 35 times
There is a "breather" hose of sorts near the fill neck that if clogged can cause this behavior...get the inlet area checked by a Volvo mechanic or indy mechanic who knows these cars.
Thanks for reporting back. I have even heard of a spider building a nest in that breather hose clogging it (on another forum).
- 647 Views
Last post by knalla1
- 1098 Views
Last post by June
- 434 Views
Last post by 1998XC70-AWD
- 11 Replies
- 2469 Views
Last post by jjss70
- 33 Replies
- 8011 Views
Last post by SuperHerman
