95 850 Headlight Adjusting
Volvo 850 Headlight Adjust
toddv850glt
- Year and Model: '95 850 GLT
How do you adjust the Headlights. I found the adjusters on the light it self but they seem not to move the light at all. Are you suppose to turn the adjusters like a screw or is adj. done with turning the bolts very little?
'95 Volvo 850 Glt N/A 5spd.
'96 Pontiac Grand Am
- Has thanked: 2856 times
- Been thanked: 1332 times
That's me using a screwdriver to adjust one just a few weeks ago. It's not the big spinner (on the right in the photo). The bubble level is only marginally useful. The best thing to do is point them against a wall, and mark where they were so you can see how much change you're dialing in.
toddv850glt
I tried that but the light seem not to move at all. Is there a possibility that there stripped out? I have spun that a few times without no go. I guess ill have to take the light out and check for stripped gears. Thanks for your help
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
the headlight housing itself does not move. the lights inside the housing are what move when you turn the wheel.
the bubble isn't that helpful. You really need to do this at night, about 25-40 feet back from a wall, with some sort of reference point on the wall. I used my garage door, since it has lines on it.
I'd adjust it, go for a drive, then come back and adjust it until it was where I wanted it. The bigger wheel adjusts side to side angle of the lights. That's personal preference, but I keep my passenger side adjusted out some, mostly to catch deer. You usually see their eyes before you see them.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- 1156 Views
Last post by Graemer
- 647 Views
Last post by Ou2mame
- 450 Views
Last post by tango_1000
- 1323 Views
Last post by 93Regina
- 1335 Views
Last post by erikv11
