Next step for me is to change the timing belt on my car, god knows when It was done last time. Does anyone have some good instructions for this, do I need any special tool?
thanks in advance.
440 B1U -95 How to replace timing belt?
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Special tools are listed in the attached instructions. The only one that may cause a problem is the tension gauge.
The belt should be replaced every 60,000 miles (96,560.64kms give or take a centimetre
) or 72 months, whichever occurs first.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Thanks mate, your service is amazing. I've recommended you to a swedish forum
My replacement belt doesn't have any markings, how do I know where to place the belt?
Another question: this hole for locking the crankshaft with 8mm bolt, Is It to the right of oil dip stick, there I can find a torx bolt. Is it this one?
- billofdurham
I have checked with another book which does not mention marks on the belt and I have never changed a timing belt that did need to be aligned with the timing marks.
The hole for the timing pin is covered by a plug so I doubt that it will be a torx bolt.
Bill.
Bill.
Previously:
Previously:
Ok, that's good.
I can't find this plug, you have a picture or something showing where It is?
Another thing, On the gearbox housing there are some marks that should be aligned with a mark on the flywheel. The marking on the gearbox is from 0 degrees to 8 degrees. There are 2 line for 0 degrees and then 3 lines for 8 degrees. Where should the marking be? Or maybe this doesn't matter as I lock the crankshaft?
- billofdurham
The only picture I have is on the attachment above at #4. The location in the attachment is borne out by the other book I have as
The only other thing I have been able to find is in VADIS parts. Looking at the engine assembly it is possible that the plug is #8 as it is near the dipstick tube and lying at the right angle to be #4 in the original picture.
If you are locking the crankshaft the positions of the marks on the flywheel and gearbox should not change.
Bill.
There are no pictures at all in that book.Remove the plug near the dipstick tube.
Bill.
Previously:
Previously:
- 5217 Views
Last post by jimmy57
- 23 Replies
- 17031 Views
Last post by jonesg
- 20 Replies
- 17329 Views
Last post by Hurtfeelings
- 1875 Views
Last post by 93Regina
- 23 Replies
- 3287 Views
Last post by 98v70dad
