Car dies when A/C is turned on
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
woody110268
Year and Model: 2002 S60/V70XC
Post by woody110268 »
I am having problems with my Volvo, I tried to charge the AC but before I even got started the vehicle shut off when i turned the AC on max. I didn't have this problem before I started the charging process but now I can't even turn the ac on without the car duying.
2002 volvo V70 XC
2.4 TURBO
AUTO TRANS
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Welcome to MVS.
This isn't an A/C issue...seems more electrical. Check your leads from your battery as well as your ground wires for corrosion or loose contacts. Do you have any other unusual electrical symptoms?
slc10844
Year and Model: 2002 XC70
Post by slc10844 »
Is the compressor locked up?
If it is your belt would be squealing like a pig.
VCA
Been thanked: 5 times
Post by VCA »
MadeInJapan wrote:If it is your belt would be squealing like a pig.
Not necessarily. I had a Buick that locked up its A/C compressor and there was no squealing (and this was a torquey 3.8L pushrod V6)--the engine would just die; shocked the heck out of both me and my mechanic.
2008 S80 T6 AWD
1999 S70 GLT
okay, then I stand corrected...I suppose you could pull the serpentine belt off and see if the compressor turns by hand- it should.
