Power steering pump replacement (1995 960)
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
drmud
Year and Model: 960 1995
Post by drmud »
I am having difficultly removing the pulley from the pump. I tried using a common puller but that doesn't do it. Is there a nut inside the hub or do I have to screw a bolt into those internal threads? Typically I have found the 960 easy to work on once I discover the "trick".
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Unfortunately I only have instructions for removing the pulley for the 940 but, having checked several references, they seem to use the same pump with a different pulley (the belts are different).
There is a special Volvo tool, there's a surprise.
940 press tool.pdf
(178.42 KiB) Downloaded 602 times
The VADIS instructions for removing the 940 pulley are in the next 2 attachments.
940 power steering1.pdf
(595.01 KiB) Downloaded 880 times
940 power steering2.pdf
(766.61 KiB) Downloaded 525 times
There is no picture of the tool #999 5443. The procedure may be the same for the 960 but I give no warranty.
Bill.
960 press tool.pdf
(178.42 KiB) Downloaded 421 times
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
drmud
Post by drmud »
Hey Bill,
Thanks. I can see how to remove the pulley with my standard puller and I can see how to press the pulley back on. The identification of the saginaw 999 5444 tool led me to the website that has very clear pictures. Thanks again.
Eric :)
