1994 960 thermostat and sensor
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
jlf
Year and Model: 960, 1994
Post by jlf »
1994 960 needs sensor associated with the thermostat and a new thermostat. Where is the sensor; can this job be accomplished with mid-range skill level.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Both jobs can be done quite easily with minimal mechanical knowledge.
960 thermostat.pdf
(697.98 KiB) Downloaded 145 times
Location of sensor:
960 temp sensor.pdf
(274.69 KiB) Downloaded 71 times
When replacing the sensor disconnect the battery negative lead, having made sure you know the radio code, disconnect the sensor and unscrew it. Do this job before you refill the coolant system. When refilling the system pour the coolant in slowly to minimize air locks.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
