If you have power window problems (740)
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
GSmith
Year and Model: 740 wagon, 1990
Post by GSmith »
This is just my recent experience:
When I purchased my 740, the previous owner said that the front passenger window motor worked okay, but that it probably just needed a switch.
Purchasing a power window switch from the local junkyard ($4.00), I installed it in the front passenger door and the window went down. Eureka! Much to my dismay, however, it would not go up.
After much fiddling, I determined that the switch for the front passenger window on the driver's door would only work if I applied pressure to the bezel.
Another trip to the junkyard and I replaced the whole block of switches on the driver's door ($10). Eureka! Now the window goes up and down from either switch.
Maybe I was just lucky that it was the switches, but if you have similar problems then that's where I would start.
1990 Volvo 740 wagon - 315k purchased 4/09
