99 S70 T5: Blown headgasket?
viriiguy
Year and Model: 99 S70 T5 SE
Post by viriiguy »
Well....
I was out looking over the vacuum lines again today with the flashlight, and I saw this..
Back side of the engine, seems to be oil right about where the seal is. I do not have any white film on my oil. It does smoke white smoke and runs rich. Idle has been rough for a while now, hence the checking of the vacuum lines.
What do you guys think?
Thanks,
Randy
bigric
Year and Model: 98 V70 NA
Post by bigric »
That's just seepage at the upper head; the only thing that flows through there is oil. Not a big deal. The head gasket is under the lower head.
viriiguy
Post by viriiguy »
That is a relief :) I went out today and scrubbed the entire engine bay, got rid of the gunk and muck left over from winter. I will keep an eye out for more leaks/seepage over the next few days. I still can;t find the reason for running rich and rough idle though. She run good under load, but idles just a bit rough.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
air leaks....small vacuum hoses or even intake manifold...spray some carb cleaner around things at idle to see if there's a surge- maybe you'll find a leak.
a2matt
Year and Model: V70 GLT 1998
Post by a2matt »
Symptoms of Blown Head Gasket: bubbling coolant, oil in coolant, coolant in oil.
My guess is a bad rear cam seal. I had a lot of oil where you are showing. In my case, it was a leaking rear cam seal. It leaks on the side of the engine then makes its way to the back. $10 in parts and an hour or two your first time at it.
If you decide to do the cam seal, it is a great time to swap some of the old vac hoses for silicone, since you need to move them out of the way to get at the seal.
viriiguy
Post by viriiguy »
MIJ, I went all around the engine last week with carb cleaner and had no surges. I had considered replacing the vacuum lines anyway, assuming they are 10 years old. However, when I was scrubbing the engine, I noticed that the hoses all seem to be in very good condition. Not brittle at all. So I am guessing they were replaced not too awful long ago.
a2matt, I will keep a close eye on the leak and see what it does. In any event, I will be replacing a seal or gasket somewhere, I am sure.
Now I have asked a couple times on a couple Volvo forums, with no answer... What is the benefit of Silicon hoses over the OEM Rubber ones?
dan2286
Year and Model: 94 850 N/A 5 Spd.
Post by dan2286 »
Silicon hoses don't dry rot and crack like rubber does. I don't know if they are supposed to last forever, but if not, they should last much longer than regular hoses.
viriiguy
Post by viriiguy »
Ahh, so no performance gains or anything. They look cooler, but I am not sure if the price difference is worth it. Especially considering at 10 years old now, ANY new hoses would likely outlast the car.
You are probably right but I bought the Stylinmotors.com kit for my S70 and had plenty left over. When ever I see a bad hose, I just go ahead and replace it with the silicone (no matter what car)... great peace of mind.
