1996 960 just quit and does not start back up.
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
yoderfunk
Post by yoderfunk »
Hi, I have a 1996 Volvo 960 and it just died on me the other day as I was turning a corner. It had done this a couple of times before but always started right back up. This time the car will not start. It turns over fine and is cranking good. The check engine has been on and I ran a OBD on it and it came up with O2 sensor and some other sensor in the exhaust lineup. What do I do now? I am lost and need to find the way. I have limited resources and would like to fix this myself if possible or at least know for sure what it is that needs to be done with it. Thanks ahead of time for any feedback.
YoDerFunK
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Cutting out during turns is usually indicative of a problem with the in-tank fuel pump.
However, before committing to that what were the fault code numbers?
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
yoderfunk
Post by yoderfunk »
the codes were C,EV,2A,O,OH,E whew....
YoDerFunK
billofdurham
Whew indeed.
Usually an OBD reader gives a four digit number which can then be checked against a list of faults. The codes you have given don't mean anything to me.
Bill.
Previously:
