Now I have to ask the “My car won’t start” question.
Just finished a 900 mile drive. No issues. Some high altitude, some serious climbing (that was yesterday), Interstate cruised at 75-85 all day.
Parked out front, doors won’t lock with fob. Key locks only drivers door. Replaced battery, no change. Checked door lock system fuses 34 & 35 on the side of the dash - they’re fine, both mirrors work.
Put the key in the ignition to check these things, there’s a new CEL on. None during the trip.
Started it up, died in 5 seconds. Now it just cranks, no start.
Why do I go anywhere??
Door locks quit, CEL came on, won’t start now.
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
I did put a small bottle of Lucas injector cleaner in it 180 miles ago, on a full tank.
When I started it, I noticed the tach dropped to zero right away.
- ignatz
- Year and Model: 2006 S60 t5m
- Has thanked: 18 times
- Been thanked: 33 times
I copied this sequence from a post I made from about a week ago.
I found a YouTube video showing how this happened to another Volvo and this is what he said to do.
With the "Key" only.
Lock and fully unlock the car with the key.
Then get in the car, shut the door and turn the ignition completely on and completely off 5 times, then on the 6th try, start the car.
After trying to start my car for days, it started right up. "Supposedly" this reacquaints the key with the ECM.
Worth a try.
Worth a try.
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
2005 S60 2.5t awd
- BlackBart
OK….i pulled a bunch of critical looking fuses in the engine fusebox and the dash end cap. All fine.
I tried your trick - started up, CEL gone, it’s idling. Only thing new is SRS-AIRBAG SERVICE URGENT in the info window. That’s pretty random.
- BlackBart
So, related to the imobilizer? Did I bump the key fob wrong or something?
I may go have it scanned and clear the airbag code, that’s random. It has a new steering wheel bag done at a dealer.
Funny - there IS a dealer here where we’re visiting. They once gave my car a sideways look and said they could get me in in 6 weeks.
- Has thanked: 987 times
- Been thanked: 1075 times
Oh no! Car trouble during the road trip?
- BlackBart
Exactly. Why should I ever go anywhere again, if something breaks each time? One time my Audi engine blew up, full of fresh new oil.
Vova585
- Has thanked: 228 times
- Been thanked: 238 times
Lets start with basics.
1) simple obd scan- what codes you have?
2) any chance you have vida/dice?
Most important- car that breaks at home, deserves to be repaired
I doubt injector cleaner is at fault here. CEL is of an interest. Good scanner should be able to pull "history" codes which might give you guidance further. I can see how crank, no start can be related to immobilizer acting up, but door lock/unlock is usually issue with leaked auto dimming rearview glass(fluid leaks onto the module inside the rearview and it is toast)
- DavidE7
- Year and Model: 01-07 V70, S60, XC70
- Has thanked: 66 times
- Been thanked: 93 times
Always bring VIDA and DICE on trips!!! My 2004 XC70 has had the most electrical issues out of my entire collection. Only time I have a problem is if I left VIDA-DICE at home. This reminds me that I need to buy a third DICE equivalent scan tool for my middle kid and load the VIDA software on his computer before he goes back to school.
Putting a P2 Volvo into the sensitive scan mode helps find random and intermittent fault codes. Airbag codes won;t clear themselves in my experience. You need a scan tool to reset the error. Being able to monitor air-fuel ratio, oxygen sensor output, VVT cam angles, and the thousands of electronic actuation possibilities to see if there is a switch or actuator or sensor problem is invaluable.
I hope your Volvo goes back to being the boring, extremely comfortable, and reliable transportation it is supposed to be!
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
- 603 Views
Last post by jimmy57
- 673 Views
- 1917 Views
Last post by matthew1
- 2756 Views
Last post by SuperHerman
- 315 Views
