1994 940 driver's window not attached to regulator
Forgive me if I don't use the proper terms. Basically, I have a '94 940 whose driver's side window is not longer attached to the regulator. It is a powered window and when I took the door panel off, it appeared someone else had used black rtv to try to hold the window to the track on the regulator. I have gotten the black rubber piece from the dealer and attempted to put the window into the track with the rubber sandwiching the window. Thinking it is a compression type of fit. The track is not wide enough to have the rubber doubled around the bottom of the window and it doesn't hold it if I just have the window and the rubber not wrapped around the bottom. I am looking for any advice to help me with this. The plastic over the window is annoying. Thank you for any help.
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
The rubber strip should be put into the lift rail and the glass is then fitted into the rubber strip. It is a tight fit to prevent the glass coming out. Try running a little liquid soap (washing up liquid is ideal) onto the rubber before pushing the glass in.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
