S80 transmission noises - buzzing
Hi My S80/2.9 //90k miles...has an intermittant buzzing noise almost like a pump noise from the transmission. It runs great and I get no check light or codes. From what i read here it seems that i am about to fail. It also seems that it has done this for a number of years, so i have been letting it go. Would a fluid change help??.....thanks, LOU
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
It might. Or the transmission might already be too far gone. Some people say that if you change it the new fluid will break loose gunk in the trans and cause it to fail earlier. I don't agree with this opinion. If you are afraid of that happening, you might want to do a partial fluid change by just dropping the pan and changing the filter, then refilling. That changes about 1/2 the fluid because the rest is in the torque converter and innards of the trans. Then you could drive a few thousand miles and do it again. That should get most of the gunk out and you will have 75% new fluid at that point. If you want to do it, here is a how-to: https://www.matthewsvolvosite.com/forums ... 11&t=20278lous80 wrote:Hi My S80/2.9 //90k miles...has an intermittant buzzing noise almost like a pump noise from the transmission. It runs great and I get no check light or codes. From what i read here it seems that i am about to fail. It also seems that it has done this for a number of years, so i have been letting it go. Would a fluid change help??.....thanks, LOU
neworleans
- Year and Model: 2007 S60R
hello lous80,
check this link out as well, you may want to do the flush by this method.
http://www.volvo-forums.com/t26151-tran ... change.htm
all you need is 9/16in vinyl tube...
be carefull on what type of fluid you put in...
- 2257 Views
Last post by Mn10
- 1109 Views
Last post by GDATL
- 13 Replies
- 2518 Views
- 485 Views
Last post by Reilly2004
- 4040 Views
Last post by SimLyons
