Ok,
Went to drain the radiator per previous advice and the petcock is broken off. How else do I drain the radiator? The lowest hose's clamp is pointing up, hoping not to have to cut it off.
V70XC '98 Cooling part II - petcock broken
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
Can you access the clamp from the top?
OK, fine - state the obvious, no wonder your a moderator
- yes I went back in the garage frustrated and noticed I could get my 30" screwdriver on it just enough to get it loose, then I was wishing I hadn't posted so quickly
I've filled and run it. The fans now work - temp sits right at 3:00 position. The connection at the firewall is still a bit suspect - I can hear a faint air hiss there that changes as I put pressure on the hose. Worried with vibration/motion it will blow again.
Also noticed that the A/C isn't working right. I turned it to full cold and the compressor did not kick in - the clutch did not engage. Several minutes later it did, but for about half a second then released, then cycled like that with 3~5 second gaps...
'06 XC90 V8
Pearl White, Premium Sound, Wood Steering Wheel, 18" Wheels, Certified Warranty
vegasjetskier
You are either low on freon (likely), high on freon (not likely), or your clutch gap is too large (possible). Have you had the system serviced?KenC wrote: Also noticed that the A/C isn't working right. I turned it to full cold and the compressor did not kick in - the clutch did not engage. Several minutes later it did, but for about half a second then released, then cycled like that with 3~5 second gaps...
vegasjetskier
If you want to recharge the system yourself, read through this thread; it covers the basics: https://www.matthewsvolvosite.com/forums ... =1&t=20392
I would assume freon low - I would guess when the thief was working on it he let the gas out and assumed it wouldn't be checked on the test drive.
HA HA HA HA - Had the car serviced? I've spent $2,400 so far since buying the car a month ago. I've just been focused on getting it to run - or at least run and keep all it's fluids in!!! Maybe I should pull back out all the engine warning lights like when I bought it. Ignorance was bliss!
I do have a few cans of R134 left from a project I didn't do...I used to have a neighbor that was a refrigeration guy. Boy, that was the life, I helped him on electrical, he kept my cars blowing at 40deg's! I'll check the link you left.
Thanks!
Thanks!
'06 XC90 V8
vegasjetskier
Drive it over to my place - I've got a pump and gauges.
I'm on my way! I was just waiting for the invite, didn't want to be rude and show up unannounced. Let's see, Seattle to Florida, roughly 7-days in a good working car, so if I plan it right and hit all the Volvo dealerships and mechanics I could get there in about 3 months...
'06 XC90 V8
