940 is shaking as if the trunk is about to fall out...
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
ccnavin72
Year and Model: 1995 940 turbo
Post by ccnavin72 »
I have a 1995 940 turbo that has begun shaking very hard from the rear, and haven't the slightest idea what it could be.
It almost feels as if the trunk is literally going to fall to the ground.
Earlier that day, I noticed a noise in the trunk area (when stopping or accellerating), and thought it was my son's equipment bag in the trunk (a "clunk" sound). Now I can't accelerate at all in drive without the shaking. There is no shaking when in park or idle.
If anyone has a suggestion or advice with what the problem could be, I would greatly appreciate it! I want to have some idea of what is going on before I take it to a mechanic.
Thanks again!!
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
You could have a wheel out of balance or bent or a bad tire. Did you hit anything recently? I'd take it to a tire shop right away and have the wheels checked. While they have it on the lift they can take a look to see if anything obvious is wrong with the suspension. In any case, don't drive it too far (or very fast) with that vibration.
ccnavin72
Post by ccnavin72 »
Hey, I wanted to drop back in and let you know what happened...
I read your response regarding the suspension, and kept that in mind, while I called to make towing arrangements with the repair shop.
Luckily, my "better half" came home early, and was able to fix the issue himself. As it turned out, I somehow lost a bolt from a bar that is located under the trunk (runs across - from left to right). They came apart and was causing the shaking.
Thanks again for your suggestion!!
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Thank you for the update.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
