1989 740 brakes make the engine idle faster
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Tiger17
Year and Model: 1989 Volvo 740
Post by Tiger17 »
Hi,
I've got a problem with my brakes on a 1989 740 wagon.
When I press on them they make a compression noise, which is a bit like a hiss, and that's fine, they've always done that. But when the pedal is depressed fully they continue to make that hissing sound, and they make the engine idle about 200-300rpm faster, or 300rpm slower (although it only did this once - and the poor car almost stalled!) The brakes still work like normal, so the increase in revs doesn't move the car, but I'm unwilling to drive it because I don't know what's wrong. :( Does anyone have any ideas?
Cheers
DeRail
Year and Model: None
Post by DeRail »
Hi Tiger17, welcome to Matthews Volvo Site!
It sounds as if you may have a vacuum leak somewhere. Check all vacuum connections and make sure that none of the hoses have developed any cracks.
When you leave the car overnight and start driving in the morning do you notice the brakes hard to press lately? If so, it could be indicative of the brake booster leaking, or it could be a small valve on the booster that is failing.
Post back with questions or findings,
Darrell
