V70 T5 2002 Sputters when starting cold
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
pjtoy
Year and Model: V70 T5
Post by pjtoy »
2002 V70 T5 (Turbo) sputters and bucks when started cold after sitting overnight. Acts like it is running on 3 cylinders. Smooths out after a few minutes and runs fine for the rest of the day. 90,000 mi. Just changed the plugs as I figured bad plugs were the problem. Didn't help. Also if placed in gear, power brakes have little boost until the engine setteles out.
Any ideas what is causing this?
pjtoy
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Welcome to MVS.
Do you get any trouble codes from the OBD-II socket?
These will help us pinpoint things more easily.
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
pjtoy wrote:2002 V70 T5 (Turbo) sputters and bucks when started cold after sitting overnight. Acts like it is running on 3 cylinders. Smooths out after a few minutes and runs fine for the rest of the day. 90,000 mi. Just changed the plugs as I figured bad plugs were the problem. Didn't help. Also if placed in gear, power brakes have little boost until the engine setteles out.
pjtoy
Sounds like maybe the water temp sensor is bad.
pjtoy
Post by pjtoy »
No warning signals, should I invest in a code reader?
Actually, (wife's car) it starts OK but sputters for about 1 minute when put in gear - then smooths out.
vegasjetskier
You should be able to go to Advance Auto, Pep Boys or Autozone and have them read the codes for you.
pjtoy
Post by pjtoy »
Good idea. Will do and report back.
Paul
