At brake pedal vacuum leak hiss!
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
fsk
Year and Model: 2001 v70 2.4T
Post by fsk »
Do not want to replace brake vacuum boost canister. There is a rubber boot on the shaft of the brake pedal under the dash. It has a few indentations/openings that looks like there is a reed/flap below which seals when the motor produces a vacuum for the brake booster. It is leaking sometimes there where I hear the hiss. Is there an adjustment like rotating the shaft. Does it have threads at the end attached to the booster?
Thanks for any previous experience with this problem or technical knowledge about this boot/reed valve function.
