My low beam lamps are way out of adjustment on my 1999 S80. Can anyone tell me how to go about adjusting them? Where are the adjustments?
Thanks in advance.
Adjusting low beam headlights
Guest
Roy. I just did this on my C70. There is a little tube poking out the back of my headlight assembly, towards the bottom and right in the middle. It juts back about 2 inches, and then goes up about 3/4 of an inch. The top of the tube is a white plastic piece with a phillips head screw in it. If you stick a phillips head screwdriver in the top of that tube and turn it, you will adjust the lights up and down.
