89' 740 GL Wagon Cold start problem solved!
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
POsubVolvo
Year and Model: 740GL, 1989
Post by POsubVolvo »
Finally SUCCESS! My 89' 740 GL Volvo SW is running like a dream. No more cold start problems and all the codes are clear and no more check engine lights appear. It ended up being the ECT sensor (rear one for fuel injection)for a third time. The first new one I put in I got from the dealer and it was bad. The second one I put in was after market with a blue plastic bottom and turned out to be the wrong one. This third one I ordered was from Voluparts out of Atlanta, Ga. it had the black plastic bottom and it solved all my problems. How strange is that? I also took the Radio relay from the 90' 740 Turbo SW I have for parts and put it in my 89'. It helped a bit but didn't clear any of the codes. I was able to find a garage to put in a new AC evap for under $450 so I never did pull the one out of my 90' to use but thanks for all the instructions. I did however have fun pulling all the parts out of the whole dash that I may need later or sell to others. But now my car is running great and keeping me cool during these hot GA summer. Again, thanks for all your help.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
To get one bad/wrong sensor is bad luck. To get two bad/wrong sensors.........you must have really upset somebody! :wink:
Good to know you are up and running and thank you for the update.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
