a/c compressor runs all the time
780 bertone
- Year and Model:
1989 Volvo 780 Bertone.The compressor clutch does not disengage,it will run continuously as long as the a/c switch is on.If you turn the swich off it will shut off. Thanks for any suggestions.Have replaced a/c low side pressure switch,and relays under the dash.
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
Are you getting cool air out of the vents? Does the car cool down to the temp you have chosen?
780 bertone
- Year and Model:
Yes cold air is coming out the vents it will run continuously,burnt up clutch on old compressor,replaced compressor,charged system,same problem clutch will not disengage.
vegasjetskier
I can't find a wiring diagram for your car, but perhaps you have a stuck relay.780 bertone wrote:Yes cold air is coming out the vents it will run continuously,burnt up clutch on old compressor,replaced compressor,charged system,same problem clutch will not disengage.
780 bertone
- Year and Model:
Replaced relays under the dash.
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
ECC? Is the control unit showing any fault codes?
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
vegasjetskier
Do you have ECC or manual control?780 bertone wrote:No fault codes
