Is cruise control effected by a failing ETM
jjbeck
Year and Model: 2001 xc
Post by jjbeck »
When my ETM was failing, I noticed my cruise control wold not work properly but once the ETM was replaced it now works fine.
So does the failing ETM effect cruise?
Jen
Current Volvo: 2001 XC
Past:
96 850T
89 740
84 240
82 240
DonWillson
Year and Model: 2000 V70XC
Post by DonWillson »
jjbeck wrote:When my ETM was failing, I noticed my cruise control wold not work properly but once the ETM was replaced it now works fine.
Would you post more information on the symptoms of the failure and how it did not work properly. Did it hesitate and surge? Did it drop out? This information will help others identify a failing ETM.
Thanks,
Don
Announcing my affiliation with XeMODeX, Inc. as Internet correspondent and consultant to Volvophiles needing help with failing ETMs. See http://FixYourETM.com. For the full history of this problem see http://VEXEDvolvo.org
VCA
Been thanked: 5 times
Post by VCA »
Yes. Straight from VIDA is a list of what happens when the ETM detects an internal fault or the ETS (system) detects a fault in the accelerator pedal or a communication issue:
  • the accelerator pedal (AP) is ignored when braking
  • the cruise control cannot be activated
  • the engine speed (RPM) is limited using fuel shut off. The maximum permitted engine speed depends on the accelerator pedal (AP) position
2008 S80 T6 AWD
1999 S70 GLT
