240 A/C not working
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
newmex999
Year and Model: 240DL 1985
240 A/C not working
Post by newmex999 »
The A/C on my 1985 240DL stopped working. Fuse 12 blows immediately every time I turn on the thermostat. Also about a week ago the compressor belt broke and I replaced and a/c worked fine till today.
Any help would be appreciated!
pbrodersen
Year and Model: 2002 S60, 1992 245
Post by pbrodersen »
WAG's - look for a short in the ac wiring - the wire to the compressor, wire from the low pressure cutoff switch, etc. You have an '85, so perhaps the insulation is cracked off and exposing the wire underneath. Could the compressor have seized, thus causing the belt to break? Jumping the compressor wire to positive terminal of battery (with engine off) will tell you if compressor clutch is working (click on when power supplied, off when power removed).
