850 GLT, 1995, SRS light stays on
squeaky3
Post by squeaky3 »
As soon as I disconnected the airbag to replace it, the SRS light came on. I thought when I reconnected it after I replaced the airbag, it would go back to normal, i.e., off. I reconnected it, both the violet and the orange harness and battery, but the light is still on. Isn't there a code I can enter to erase the light? Is there something else I need to do? The replacement went without a hitch except for the light. Thanks.
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
Put the fly wire from your diagnostic unit into port B-5. Read all of the codes.
Once all of the codes are read press and hold the button for 5 seconds. Let off of the button and the LED should come on again. while the LED is on, press and hold the button for another 5 seconds. That should clear the fault.
squeaky3
Post by squeaky3 »
Thanks for your help. I'll try what you told me. I'm guessing the diagnostic unit is the gizmo on the passenger's side under the hood. But how do I "read all of the codes"? If you can tell me that, I think I can do the rest. My Haynes' Manual told me to disconnect the negative terminal, put the ignition into the #2 position. Connect the negative terminal. Turn the ignition off. Then start the car and in 10 seconds the SRS light will be gone. Didn't work! And I tried it half a dozen times. Another issue is the Service Light. I followed the instructions, maybe yours, in "Reset Service Light Volvo 850, S70, C70, XC70," on this site. That didn't work for me either. Thanks again.
Squeaky3
Richard Manson
Post by Ozark Lee »
Snag a copy of the factory service manual from here:
https://www.matthewsvolvosite.com/downlo ... vo_850.zip
Once you unzip it see the file named air bag restrain system.pdf.
It will walk you through the procedure to test and reset the system, if you get any error codes it will also walk you through test procedures.
Don't use an Ohmmeter to try to test any of the airbags as it can actually trigger them.
Post your codes back but my bet is that your clockspring connection on the steering wheel has failed.
squeaky3
Post by squeaky3 »
Once again, thanks for your help and for being so quick about it. I assume in pointing me to the service manual, you think this is a procedure a novice, me, can do himself. I'll certainly try. If, as you say, the "clockspring connection" has failed, is that something I can handle also? And how will I know it's failed? And what is it?\
Squeaky3
Richard Manson
Post by Ozark Lee »
The diagnostic portion through the A/B boxes takes no special tools - just a pen and paper to mark down the LED flashes. The clock spring connection is in the base of the steering wheel and provides the trigger to the airbag in the center of the steering wheel. Since the steering wheel is always moving it is a slip ring and that is really the only moving part in the system.
Most of the time a fault code 2-1-2 means the clock spring is bad.
Replacing it isn't a real challenge, there are two screws that hold the airbag on and then one nut that holds the steering wheel on.
The procedure is very well documented in Step 4 in this writeup:
http://www.woodjoiner.com/volvo/
squeaky3
Post by squeaky3 »
From what you wrote about the clockspring, I'm thinking I should have mentioned the airbag I replaced was NOT the drivers side but the PASSENGER side. Does that alter your diagnosis? Secondly, when I went to the woodjoiner site you referred me to, all I found was info on AC evaporation systems. (I should also have mentioned I'm basically computer illiterate.)
squeaky3
Richard Manson
confused_al
Year and Model: 1996 TLA wagon
Post by confused_al »
In case Lee is busy this morning...
squeaky3 wrote:...NOT the drivers side but the PASSENGER side
Then you dont have to worry about the clockspring for now, even tho there is still a chance it went bad (thats why Lee want you check your codes).
squeaky3 wrote:I followed the instructions, maybe yours, in "Reset Service Light Volvo 850, S70, C70, XC70," on this site. That didn't work for me either.
This link will help:
http://volvospeed.com/850slight.php
From this write-up and the pics you should have an idea what Lee was talking about,
Ozark Lee wrote:Put the fly wire from your diagnostic unit into port B-5. Read all of the codes.
This link will give you a bit more info:
http://volvospeed.com/CheckEngine.php
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
Post by Ozark Lee »
I re-read your original post and I am back to just clearing the codes and you will likely be fine.
squeaky3
Post by squeaky3 »
Once again, thank you. I haven't tried the procedure yet, but I will. While I waited for your response, I called various top-flight European car mechanics, including Swedish car specialists. They all told me the procedure for clearing the codes, or that particular code, is proprietary information not divulged by Volvo, so I would have to take the car to a dealer. I'm hoping you're right and they're wrong. We'll see. Thanks.
Richard Manson
