740 240k miles looses power on highway
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
efinet
Post by efinet »
I have a 740. It has been driving great for the past 4 years when I got it.
Oil and water are ok. No nocking sound.
The car starts properly, however I can not drive faster than 30mph??
There is a hissing sound comming from the front??
What could this be? I would apreciate help as I need this car for work and can not drive on a highway with it!
Thanks :D
gc
Post by gc »
At this age, the converter may be used up and clogged, limiting the engine's ability to breath.
Can you bypass the converter and see if the problem disappears?
ber
Post by ber »
I had a similar issue with my '88 740 gle and I was told the mass air flow sensor might be faulty... When you shut off the car it should click twice right by the air filter. If not that sensor might be bad, stopping your engine from getting the proper air/fuel mix. Or maybe you just have an vacuum leak. Check your hoses...
