1988 240 DL Cooling system Leak
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
NickWhit
Year and Model: 1990 740 gl
Post by NickWhit »
Several days ago I discovered, much to my horror, that my coolant reservoir was bone dry, and that my floor on the passenger side was mysteriously soaking wet. Checking under the dash, I found the source of the leak, a pipe which comes out from beneath the glove compartment at a right angle and continues on into the center area of the dash behind the AC controls. What I am wondering is if this pipe can be replaced, or if once I get in there I am going to discover that this is a much larger job than it is worth as often happens. In this case, what can I patch this with? It seems that the previous owner tried to patch the leak with roofing cement, which only worked temporarily. I am not too savvy on issues of the cooling system,
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
By 'pipe' do you mean a rubber hose or a metal pipe? Obviously the leak is associated with the pipework to the heat exchanger (heater radiator). If it is one of the hoses it is a fairly easy fix but if it is metal it may need a new heat exchanger.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
