1988 240 Wagon No start, fuel delivery problem
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Burt Graber
Year and Model: 1988 240
Post by Burt Graber »
My 240 will start and run only with terminal 85 of the fuel pump relay grounded and power jumped to fuse #4. It will continue to run with the ground dropped off the relay but dies when power is dropped off the fuse. Our local Volvo expert has suggested a bad ignition switch. Any thoughts?
rgk
Year and Model: Gray 88 245
Has thanked: 1 time
Post by rgk »
Jumping terminals 30 and 87/2 should activate the fuel pump. The relay itself is suspect. These relays are known to go bad often, causing all sorts of strange problems. Seeing as how it is a cheaper part than the ignition switch, I would start there. Cheaper still is carefully cleaning all of your fuse terminals.
rgk -- was dickdeadly
Burt Graber
rgk wrote:Cheaper still is carefully cleaning all of your fuse terminals.
Bingo! Poor connection at the 25amp fuse under the hood. Passed enough current to sense voltage downstream but not enough to run the pumps. Back on the road!
rgk
Has thanked: 1 time
Post by rgk »
Excellent.
