New owner, 1995 850s 16K from new...help with shopping list
adrian1956
Year and Model: 850 1995
Post by adrian1956 »
Hi, I'm new to this lark (having had my from new 351k Mk3 escort estate stolen), with an 1995 850S estate 10v manual gearbox with 16,000 miles on the clock, based in the UK..This car is as much perfect as I can see, with minor issues..
1. I need a full kit to convert to keyless (with 2 fobs) that will fit and compliment the current system.
2. A replacement radio aerial booster or fix (I have power, to the plug, but only radio 2 now works), it's a cr-950 and was working and I would like to use my mobile FM system.
3. The trim that surrounds the passenger opening handle has a minor crack in it (new or near perfect replacement required).
4. One new NCT 2 195 60 15 would be good (as I have one already).
5. A space saver to match (to replace the spare)
6. A pointer where I can get a quick shift kit to fit.
7. I need to replace the iffy reverse light switch..which appears to be under the centre trim.
Lastly should I look to replace the airbag within the steering wheel...is there a source for one, are they silly money.
Adrian
TIA
Any help would be good.
redrider_64
Year and Model: 850T,1994
Post by redrider_64 »
Hello from USA - I often refer to www.volvoclub.org.uk They have the most complete PDF documents and resources of just about anywhere online for the DIY guys!
adrian1956
Thanks for the reply...I could see nowhere this side of the pond with any reference to the quick shift conversion...I am addressing the other issues.
Adrian
I will post on the Volvo...
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
The closest thing I have seen is a bushing set from QuickBrick Motorsports.
http://www.quickbrickmotorsports.com/prod_shiftkit.html
Sadly I have heard that he has taken ill and I'm not sure what inventory he has left. It isn't really a short throw kit but it addresses some of the sloppiness in the OEM design.
adrian1956
I found and posted on an email re the short shifter
Hopefully that will work
Adrian
mcp
Post by mcp »
Manual transmission 850 - The backup light switch is on top of the transmission.
Here is a link with photos:
http://volvospeed.com/Repair/tranbackup.php
1998 S70, 5 speed manual, 146k, wife's car
1997 850 Wagon, 5 speed manual, 185k, son's car
1996 850 5 speed manual, 220k
1985 MB 300D 268k, running on B20 biodiesel
1983 MB 300D 240k , converted to vegetable oil
1981 VW Vanagon 184k
adrian1956
That's why.....Back-up light.....as opposed to reverse light switch, when I searched I found nothing....job done now.
Thanks
Adrian
