1994 850 Wagon - Check Engine code question...
Landru3000
Post by Landru3000 »
Problem with my 1994 850 Wagon, n/a 160,000 miles.
Today, driving 65 on the freeway, the engine cuts out, tach says 0 RPM, and the check engine light (only) comes on. I give it a lot of gas, the CEL goes out, the engine kicks in, and after initial high RPM, it evens out. Then it repeats until it is on-off on-off. Pull off the freeway and it's fine.
So, even though the CEL is back off, will I be able to pull the codes that turned it on?, and which pin/plug should I read. All of them?
(fwiw, it occurred just 30 seconds after remarking how reliable the car has been.)
Thanks. Any advice is appreciated.
Andrew
Oakland, CA
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
Here's how to read the codes:
http://volvospeed.com/CheckEngine.php
Here's the list of the codes:
Lista de Codigos DTC Volvo 850 Turbo .pdf
(44.99 KiB) Downloaded 121 times
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Landru3000
misha wrote:Here's how to read the codes:
Thanks!
Do you know if the codes remain even if the check engine light went off by itself?
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
Normally they are like an elephant and they never forget anything. If you have a bunch of codes clear them and see what comes back.
Volvos are kinda unique in that they can actually set codes and codes can be read even without a CEL.
tailor
Year and Model: 2004 XC90 2.5T AWD
Been thanked: 2 times
Post by tailor »
Actually the Lamda light does reset itself after getting error codes multiple times. The problem that caused the error in the first place is not resolved and nor are the codes deleted. Sometimes codes are not cleared after a problem is resolved with a new part and these codes are refered to as ghost/ rogue codes. This is why the recommendation is to read and clear the codes first and then see which codes return so you do not go mad replacing parts that are not problematic.
Seems Ozark beat me to it!
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
