Cooling Fan won't stop
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
jimmoss
Year and Model: 2002 S60 2.4T
Post by jimmoss »
I have a 2002 S60 2.4T and today the cooling fan would not turn off. No engine code shows.
dclifford
Year and Model: S60 2002
Post by dclifford »
Curious, I have an 02 S60 and this exact same issue happened a few days ago. I've tried replacing the sensor to the left of the injectors hoping it was something that simple, it didn't help. I don't receive any codes either and when I disconnect the additional lead that goes to the fan control unit, it still continues to run. Anyone have any ideas? Is this possibly a bad fan/control unit? Is this similar to the older Volvos that provide a ground connection when the fan should engage vs. a positive lead? Any help is appreciated.
sophos
Year and Model: s60 2004
Post by sophos »
The problem is in the electronic device mounted on the cooling fan itself.
There was an service action on these Volvos in the beggining. You should contact your local dealer or PM me your VIN number so that I can check if this action is still valid on your VOLVO
