740 turbo 1988 smoking engine
wyoben
- Year and Model: 1993 940
- Been thanked: 2 times
I had a chance to buy a 1988 740 v0lvo turbo...it's smoking bad upon inspection,I noticed the flame trap ventilation system was tampered with I have worked on these turbo pcv systems and understand there is actually no flame trap,but a straight thru system ...what I noticed was the larger hose going to the air inlet to turbo disconnected...the smaller vacuum hose from intake disconnected...so basically instead of sucking the blowby back into the the engine its spewing into atmosphere...my question is would there be quite a bi of blowby and if the system was sucking and functioning correctly would this problem be resolved...the car has 200,000 miles on it and seems to otherwise run good I have not pulled plugs to examine any tips ...P.S still looking for someone to answer my question on what model volvo 16 inch rims will work on the 740/940 cars also heard some other model/make wheels will work ,like ford aerostar etc...any tips on that
wyoben
I thought the flame trap would fix it ,its probably gone ...I'm looking for the 16 inch hydras...how much and can you ship them Greydog bus lines contact me directly at [email protected] or call 307 780 5658 thanxz
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
As you said in your first post, the turbo doesn't have a flame trap. The crankcase gases are recycled through the turbo.I thought the flame trap would fix it
Where was it 'smoking bad', PCV hoses or exhaust?
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
wyoben
youre right I forgot that I already learned that lesson , the car is gone now but I think it was a pvc hose routing error on the owners part causing the blowby to be released , thanks to all for the help...I still need a good cheap set of 16 wheels for my 940...real cheap,when I consider in the shipping let me know, they dont have to be real fancy
- 611 Views
Last post by mrt740
- 68 Replies
- 11468 Views
Last post by 1ezliving4ume
- 808 Views
Last post by louie3888
- 764 Views
Last post by lummert
- 862 Views
Last post by 93Regina
