Replace speed sending unit in differential.
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Robert Smith
Year and Model: 240 1987
Post by Robert Smith »
Hi -
I have a 1987, 240 sedan.
My mechanic says the speed sending unit in the differential is broken and needs to be replaced.
His shop has never actually done this repair before and he cannot find an obvious way to get access into the differential to remove and replace the unit.
Can you please tell me how to do this - or direct me to a source for this information.
Thank you.
Robert
redrider_64
Year and Model: 850T,1994
Post by redrider_64 »
go to >>> www.volvoclub.org.uk and do a search based on the part name and your Volvo year / model.
Good Luck
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
The sending unit is mounted in the rear of the diff casing towards the top. The unit is accessed from the outside.
240 speedo sensor.pdf
(352.54 KiB) Downloaded 203 times
Depending on whether or not your car has ABS there is a choice of two sensors. In the attachment the sensors are part #11 (non-ABS) and #11a (ABS) The non-ABS is held in place by a screwed collar, part #13, which can be removed using adjustable pipe pliers. The ABS is held in by a hex socket screw, part #13a.
However, the first thing to check is the condition of the wires to the unit. Because of their position they are subject to a large amount of water, dirt, salt and many other things which can cause corrosion leading to bad contacts. They have been there for 22 years and have probably never been checked.
If you need more help we aim to please.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
