93 850 service light on only when cold below 35degrees
jschick
Post by jschick »
these last few days its been 30 degrees or colder in the mornings, today it was 23. when i get in the car and drive to work my service light comes on as soon as you start the car, the little round light. it only comes on when the car is cold, at lunch or on the way home it does not come on? so I assume it has something to do with the coldness? what does this mean? I reset the light about 600miles ago so it should not have anything to do with the service reminder. I only drive 5 miles to work and it stays on the whole time, but later in the day it will not be on, and it has warmed up to the mid 40's by then.
thanks
ADDED 11/10/04
I am reffering to the little round 1/8 inch light next to the outside temp. for the last 4 days now it has come on only in the morning which has been between 23-30 degrees. at lunch and in the evenings it is not on and it has been 40-50 degrees then? today going in to work I had to make a stop on the way, it was still on after I started the car again and the car was warm but it was 30 degrees today. mathew. I still can't reply to posts but I can edit?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1254 times
Post by matthew1 »
We're talking about your Service light? Not Check Engine?
Service light -- dumb, timed
Check Engine light -- smart, triggered by a fault
Also -> Amazon link
GUEST
Post by GUEST »
IF IT IS THE SAME LITTLE RED LIGHT BESIDE THE TEMP SETTING THAT I HAVE IT IS TO WARN YOU ABOUT THE POSSIBILITY OF BLACK ICE. I BELIEVE YOUR MANUAL COVERS THIS
