check engine light is on
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
marko2007
Year and Model: v50 t5 2007
Post by marko2007 »
2007 volvo v50 t5 check engine light on. Pulled codes it said miss fired on cylinder 4 and 5. Dealer said change spark plugs. I changed them and reset codes. 1 week later, light came on again. Car has 60k and can't figure out!! Car is now running ruff when starting. Please help. Thankyou : :?
JDS60R
Been thanked: 3 times
Post by JDS60R »
Marko,
Sounds like failed coils or a blown head gasket.
Swap the coils from cylinders 1 and 2 to 4 and 5. Then see if you get a code for misfire in 1 and 2 . If so - replace bad coils.
If no solution with that process then test the coolant for combustions gasses. If no combustion gasses in coolant then head gasket is ok.
I always test the combustion gasses first but swaping the coils is free so I listed it first.
Please let us know what it was .
Retired
marko2007
Post by marko2007 »
check engine light still on code 300 what should I do ? .
