Squeaking near steering wheel
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
DG26
Year and Model: S60, 2003
Post by DG26 »
Alright guys here's another question for ya.
When I drive my 2003 Volvo S60, and I go on a bumpy road in particular, near the steering wheel it starts squeaking, it is probably the most annoying sound I have ever heard.
I don't know what to do with it, or how to fix it, but it doesn't start squeaking when I turn the wheel like I have read other people having problems with, it's when I hit a bumpy road, it just starts squeaking so freakin' loud, it's horrible! :cry:
Anyways if you guys have any ideas please post em', thanks a ton!
DG26
Post by DG26 »
Is there anyone else that has had this problem, or has any idea on what to do to fix it?
DG26
Post by DG26 »
Been searching and searching online for any idea, and after looking for the past half hour I found this.
2003 Volvo S60 Suspension & Steering - Common Problems
* Sway bar end links wear out prematurely, causing a knocking noise from the front end when driving on bumpy roads
* The upper strut mounts break and cause a knocking/squeaking noise over bumps
* A rumbling noise from the front end at speeds over 35 mph can be from a failing wheel bearing
* Front control arm bushings wear out and can cause alignment issues and squeaking and knocking noises from the front end
I'm thinking it must be one of those, all I know is this stuff that's wrong sounds like it's gonna be expensive. Man...
Suggestions would be nice haha.
Another weird thing, is that some times when I rev the car it starts squeaking, I wanna get this fixed so bad, just hoping that it isn't as expensive as I'm thinking. :|
