Weird brake noises/feel
dan2286
Year and Model: 94 850 N/A 5 Spd.
Post by dan2286 »
I have been hearing this weird noise when braking while getting off of the highway. It does not happen all the time and is only when slowing down from highway speeds(60+ mph). The noise/feeling is almost like a grinding noise that I kinda feel in the pedal. I am not sure how else to describe this. It's not real loud but still noticeable. It's almost like something is loose. I checked out the brakes and everything looks good. Pads have plenty of meat left on them, no scoring in the rotors, everything is tight. There is no pulsation in the pedal like the rotors are warped.
Any suggestions?
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
Do you have drilled or slotted rotors? My drilled rotors have a funny sound / feel under heavy braking but they stop really well.
..Lee
meine39
Year and Model: 1995 850 GLT Wagon
Post by meine39 »
I had something similar - the noise seemed worse when coming to a slow stop on a downward incline after the brakes were fully wamed - in my case, it was the shims on the rear pads that were installed upside down. I cleaned and regreased the backing plates and shims, and the sound went away. The Volvo shims are meant to be installed with the 'cut out' portion of the shim at the bottom of the brake pad; they also have a directional arrow stamped in them - the directional arrow should face the direction of forward wheel travel.
I only use Volvo original brake parts (pads, rotors, and Volvo white synthetic grease) to avoid noise issues, on the advice of all the experts here on the site.
1995 855 GLT 190K NA Auto
1998 BMW 528im 137K
2000 Toyota Camry 78K
2010 GMC Acadia 57K
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
Where do you get the volvo synthetic grease?
meine39
Post by meine39 »
polskamafia mjl wrote:Where do you get the volvo synthetic grease?
At the Volvo dealership parts counter, part #1161688, called PTFE Silicone Grease.
1998 BMW 528im 137K
2010 GMC Acadia 57K
polskamafia mjl
Thanks a lot.
dan2286
Post by dan2286 »
meine39 wrote:I had something similar - the noise seemed worse when coming to a slow stop on a downward incline after the brakes were fully wamed - in my case, it was the shims on the rear pads that were installed upside down. I cleaned and regreased the backing plates and shims, and the sound went away. The Volvo shims are meant to be installed with the 'cut out' portion of the shim at the bottom of the brake pad; they also have a directional arrow stamped in them - the directional arrow should face the direction of forward wheel travel.
I used Volvo pads in the rear, but don't know what is up front. I have a feeling if I go to Volvo pads in the front, the noise will disappear. Since the pads still have life in them, I will deal with the noise for now.
