Should I be worried?
It idles fine, accelerates like normal and seems fine.
What is wrong?
Service light stays on for about a minute at startup...
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Completely normal; it's just trying to "remind" you that you need an oil change. I just ignore it.
Here's the procedure for resetting on a '95 if you are so inclined:
1. There are two diagnostic units(it says A and B on the cover) located adjacent to washer reservoir under the hood. Turn on the ignition and open the module A and insert the flylead into socket 7.
2. Press the button on the diagnostic unit 4 times, briefly but firmly. Then the LED illuminates and stays illuminated, and the system is ready to accept manual code input. A code number for resetting the service reminder light is 1-5-1. To do this, press the test button once and release it And LED illuminates again.
3. Then press 5 times and wait for the LED to illuminate.
4. Press the button once and LED should flashes several times in succession and the reminder should have been reset.
5. Switch off the ignition and replace the flylead in its holder and close the cover.
'98 S70 T5
2016 Chevy Cruze Premier
- 1652 Views
Last post by kaneelschep
- 2829 Views
Last post by NYVolvo1994
- 1628 Views
Last post by MadeInJapan
- 12 Replies
- 2087 Views
Last post by veektor
- 4134 Views
Last post by cn90
