850 95 - How to remove the gas pedal?
jofinneg
Post by jofinneg »
Hello,
I have a broken heater hose coupling on the firewall side. I keep reading that you need to remove the gas pedal to replace the coupling, but I cannot figure out how it is done. Is it taken off at the main pivot point, where the pedal is attached to the bulkhead? I see a metal tab under the pivot point that I've pressed up and in and out, to no avail.
There are a couple nice tutorials out there on how to remove the heater core, but I would rather not have to go that far.
Any advice?
Thanks,
John
charlyW
Year and Model: 97 855 T-5 CD
Post by charlyW »
There should be a bolt going through the pivot point of the pedal it may be held by either one or two Circlips or plain C Clips [no idea what you call then in the states] Otherwise it will be held by 2 or 4 bolts bolted to the bulk head. Will check on my 93 850 I guess they will be all similar.
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
findude
Post by findude »
Though this could be one of the things that differs between LHD and RHD cars.
1996 854 Grand Luxe n/a 5-speed
jofinneg
Post by jofinneg »
The bolts to the bulkhead are inaccessible until I can get the main pivot point off.
I believe there is a bolt at the pivot point, but it appears to be enclosed in some sort of a plastic knob on the left side of the pivot point, and I can't really see or access the right side of the pivot point due to the tight fit. There may be some type of c-clip on the right side, but it is just too hard to see or get to.
Has anyone else done this?
Thanks,
John
