960 sedan 1995 problem starting
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
osceolazulu
Year and Model: 960 sedan 1995
Post by osceolazulu »
my Volvo has run very well for the 14 months I have had it (has 100,000 miles on it), but in the last 4 days it has taken numerous attempts to start it and it has stalled on me a couple of times. The check engine light come on. I took it to Pepboys and they could not detect any problem. Upon leaving Pepboys and stopping it immediately failed to start again. A shop looked at the spark plugs and said this could be the problem-the plugs were very blackened and crusty. I ordered plugs from Volvo dealership as I was not going to trust traveling 30 miles to the nearest dealership. I am wondering do bad plugs cause starting problems, poor milage and stalling or is it something else I should also be checking..
danr960
Year and Model: 964 1994
Post by danr960 »
Is the check engine light still on? Pep Boys was not able to read the code that turned on the light?
I believe up to the '95 year, one can read the codes themself. On the driver side fender is the DTC reader. You need to get a code for a starting point.
Yes, bad plugs could cause a mis fire which in turn could trigger a code.
But I am sensing that if the car ran great until this, it is something other than just tired spark plugs.
DanR '94 964 343,000 miles (109,000 on the new engine)
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
osceolazulu, welcome to Matthew's Volvo Site.
danr960 is correct, you can read the fault codes yourself. To find out how to do it see:
960 fault code testing12.pdf
(842.77 KiB) Downloaded 134 times
As the check engine light is on there should be a code recorded. If you don't find one it may be that the transmission has recorded a fault code and that could illuminate the check engine light. If you need more help on this post back.
Bill.
Edit. Missed out the location of the OBD unit:
960 diagnostic unit.pdf
(98.97 KiB) Downloaded 181 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
osceolazulu
I am truly a novice- is this DTC reader easy to locate-
billofdurham
Its location is in the second paragraph of the second attachment.
Bill.
Previously:
osceolazulu
I changed spark plugs in my Volvo ( thanks!)..and it starts well when cold--I've started it a few times and it turns over well after sitting for awhile
Problem1 is if I drive it for 5-15 miles and turn the engine off -it will not restart until I let it cool for 15-20 minutes.
Problem2 is I still can not locate this "code box" (excuse my ignorance) - there are so many gadgets along the drivers-side fender and since I don't know what this box is suppose to look like I'm still clueless. I am going to take some pictures and maybe someone can tell me what to look for....Thanks
Wow! after looking at these pics my engine seems pretty dirty
I am thinking this may be it (codebox)?
billofdurham
Let's get it running properly then you can clean it. :wink:
The diagnostic box is mounted in front of the left strut tower and looks like this:
The top cover lifts up to expose 6 holes for the test lead.
Bill.
Previously:
osceolazulu
Thanks! in the last 2 pics (in attachment) is this the box? and where can i obtain the tool for pulling these codes?
billofdurham
It certainly looks like it. The 'tool' is attached to the box. It is a fly lead that you insert into the appropriate hole in the box - #2 for the fuel system and #6 for the ignition. The instructions are in the attachment in my earlier post.
Bill.
Previously:
osceolazulu
Thanks again!! billofdurham..I located and open box and plugged lead into #2 & #6..but ...do I hold the activation buton down until I get 3 (3digit) readings ? or press it 3 times to get the 3 number code?
Thanks again!! billofdurham..I located and open box and plugged lead into #2 & #6..but ...do I hold the activation buton down until I get 3 digit reading ? or press it 3 times to get the 3 number code?
001 (2).JPG (206.46 KiB) Viewed 1227 times
