Hey guys long time no post but my 850's sick . A few days back it started to jump and buck like crazy losing power and stalling at low revs or idle . Seemed to be the same as when the sparks needed changing so I changed the sparks . Old ones were black and sooty . No change so I disconnected the MAF . Idle improved as did power . I removed the MAF and gave it a good blow out and it seemed better well for about 1/2 a mile then it was bucking like a bronco again .
I bit the bullet and bought a new MAF . The car now idles at 900rpm but the power is still lumpy as hell . If I mash the gas it kicks and misses and the revs hover about 2500 . Adding a little gas at a time it will go to redline . Im now totally lost as to the cause and need some ideas .
Its drivable with MAF disconnected but it drinks juice like crazy and power sometimes just isnt there . Far from ideal lol.
Thanks fellas .
850 97 Losing power
FCPEURO
- Year and Model: 2006 XC90 V8
- Been thanked: 19 times
Ok, in that case, change out the fuel filter and report back.Solutech wrote:When plugs were replaced about 12 months back I replaced the rotor arm,cap and leads . All are still in good condition . The fuel filter I havent done so it may be worth replacing . The air filter again is in good shape .
Surely if the filter was clogged then disconnecting the maf wouldnt improve it . Car revs much better without the maf . But after a quick check the filter looks to be quite old . Note on UK models the filters on the drivers side
thought I was going barmy for a while looking on passenger side .
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Did you replaced it with oem Bosch one?Because if not,this is something you could expect.
Is check engine light on?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
The CEL is on as I disconnected the MAF . Its been lit for 12 months since I last disconnected the MAF trying to diagnose a similar problem . I havent had the codes cleared as it requires a reader I dont have and none of the local greasemonkeys has a reader that will link up to it .
The MAF I removed was a Bosch . The replacement is a generic unbranded OEM .
I changed the fuel and air filter earlier . No change . Idles lovely but wont rev correctly on full gas it gets to 2500-2800rpm and bounces back n forth. Smooth revving with a little more pedal at a time and it revs all the way up to redline . Again disconnect the MAF and it wont idle but revs up fine . Im running out of ideas now other than putting a rag in the tank and lighting it .
I would double check all of the vacuum and intercooler hoses for cracks and make sure they are all hooked up. And look at the plugs again $10 is about as cheap of an insurance policy to be had. Most larger auto parts chain stores will check and clear your codes for free.
