Engine shudder during acceleration
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
mikod4
Year and Model: S60 2006
Post by mikod4 »
Greetings,
I am new to this forum. I have a 2006 S60. When I slowly accelerate to 40 mph, the engine shudders for a second, then smooths out. I filled up my gas tank with a higher octane fuel, still shudders. What else would cause this. Plugs? Transmission?
rbodor3
Year and Model: 01 S60 LPT
Been thanked: 2 times
Post by rbodor3 »
is it turbocharged?
Either way, check: spark plugs, upper engine mount for cracking, lower transmission mount (smaller bushing) for cracking, PCV for clogging. My bet is on spark plugs.
01 Volvo S60 2.4T
mikod4
Post by mikod4 »
It only happens between 35 and 40 mph and it last 2 seconds then smooths out. Otherwise it runs perfect no shudder.
rbodor3
Post by rbodor3 »
does it feel like a bad shift from the transmission?
Sounds like a bushing to me.
Check the upper engine mount (upper engine, driver's side, black rubber bushing). If that's not it then lift the front end, remove the plastic catch pan (12mm IIRC), and check the lower transmission mount. As soon as you drop the pan you will see a bushing similar to the picture. Both of these are common failures for the s60. Shudder would likely be worst in low gears and bad shifts with the transmission, and would vibrate at idle if the engine mount. Any sort of cracking, or breakage at all would mean new ones are needed.
trans mount.jpg (119.22 KiB) Viewed 7850 times
01 Volvo S60 2.4T
mikod4
Post by mikod4 »
Thank you for the reply. Hopefully I can reach these mounts myself. The engine does seem to vibrate more when I put it in reverse.
mikod4
Post by mikod4 »
Checked mounting bolts and bushings..everything is fine: however when on road, car still shudders at low acceleration to 35 to 40 mph, only. When I'm on the open road or the highway, no problem. In the city or going slightly uphill, it seems like it is coming from transmission.
vorbosh
Year and Model: s60
Post by vorbosh »
Unbelievable Coincidence but I just started having the same issue. s60 2005 2.5T
If I accelerate through 40 to maybe 45 quickly. No problem. If i go about 38 steady with the tachometer at 1500 then the car starts to shudder. I guess it feels like it is caught between shifts.
I will watch the post. I will also be taking the car to a repair place on Thursday. If I find out anything. I will post.
Good Luck.
mikod4
Post by mikod4 »
I received a message " Transmission Service Required". It's at a mech shop now. I'll post what he says the problem is. Before he mentioned a transmission relay not putting out enough pressure.
vorbosh
Year and Model: s60
Post by vorbosh »
I used a friend's diagnostic tool and got the codes PO201 Injection circuit/Open Cylinder 1 and PO121 Throttle Pedal Position Sensor A Circuit Range/Performance.
Sounds like a similar problem but different cause.
Thanks for updating.
Craigd2599
Year and Model: 2007 S40.
Has thanked: 3 times
Post by Craigd2599 »
do S60's have lock up torque converters? that sounds like a converter issue
Craig D
Philly Boy in Lynchburg VA
2007 S40 Previously: 2 850's and an S80
Waiting for that "R" model barn find
