Gas Tank Removal Question + Leak photo
This topic is in the MVS Volvo Repair Database » Gas Tank Removal Question + Leak photo
outdoor7or24
Year and Model: SOLD 95 855t,93 945t
Post by outdoor7or24 »
1995 855t with a leaking hose on top of the gas tank. The yellow X is where the gas spews out when filling it up.
My question is on how to drop the gas tank. Anything special?
Any idea on the steps?
Anything else I need to replace while the tank is dropped?
Thx.
volvomileage
Post by volvomileage »
hello
although i have never removed the tank i joined a pdf, hope it can help you out
cheers !
gas tank.pdf
(1.67 MiB) Downloaded 3787 times
volvo 850 95 sedan non/turbo 185 k
outdoor7or24
volvomileage wrote:hello
cheers !
Thanks for the pdf. However, I didn't see much in it for removal of the gas tank.
This did make me remember about the manual for download on this site though...
voodoorobaz
Year and Model: 1982 Volvo 245 DL
Post by voodoorobaz »
Just don't fill it all the way up...Just kidding. is it possible to lower it just enough to get to it? enough hose left to cut off bad part or you wanna replace entire hose? Had a leak like that myself on a diff car and that's what I did. Not sure on this particular car...
1998 Volvo S70-Gone
2002 Volvo S60 T5-Gone
2000 Volvo V70 XC AWD-Gone
1983 Volvo 245 Dl-Gone
1982 Volvo 245 DL
2013 GMC Terrain with 3.6l
2006 Cannondale Bad Boy Use for Commuting to work
outdoor7or24
Anyone here dropped the fuel tank? Just wondering if there are any surprises....
renns
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 6 times
Post by renns »
My 850 leaks if filled to the max as well. I'll watch this thread to see what I'm up against. So far I'm stopping the fueling as soon as the filler valve kicks off the first time. If I don't, that last litre or so that I add will end up on my garage floor by morning.
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
outdoor7or24
Done.
I took some photos along the way and will post a 'how to' this week with those photos.
It was easy to remove, but a little harder to put back in place.
outdoor7or24
Folks sorry for the delay... House renovation and traveling.
Here is the write-up.
I followed a link on volvospeed.com - - as a reference. Mine was a little different.
1. Disconnect the negative battery cable for safety.
2. Block the front wheels, jack up the rear, use some jack stands to hold up the rear.
3. Remove the floor board to open up the area to access the top of the fuel pump and sender.
4. Unbolt the cover over the fuel pump and sender. Unhook the electrical connectors so they can go through the hole when dropping the tank.
5. There is a circlip that holds the fuel filler in the door. Pop this out so you can lower the tank with the fuel filler. Just push out the rubber seal so it comes out of the fuel door hole.
6. Line up a floor jack to support the gas tank when you unbolt the supports. There are 3 bolts that hold up the metal band supports. Unbolt them and use your floor jack to slowly lower the tank while guiding the fuel filler tube as you slowly lower the tank. Move the metal bands out of the way and lower the tank. Make sure your electrical connectors come through the holes without getting hung up.
7. With tank down, you should be able to slide the jack out and and replace the cracked hose under the car.
8. The Cracked hose. It just poured fuel out when the tank got full.
9. This is where I noticed my hose was different than the volvospeed.com post. I had a molded rubber hose that had ends with different sizes. I got some 3/4 inch fuel hose that would fit on the tank vent hole end. I cut out a good section of the original hose and slid the 3/4 hose over this, used a little JB Weld to seal the end, added a hose clamp and put 'er back in place. So far this has worked. However I noticed I cannot use the fuel pump at full speed due to fuel backing up.
10. After hooking up the hoses, get your tank back on the floor jack and begin the process of raising the tank. Make sure your jack is not in the way of the metal supports. Guide the filer hose back up to the filler door as you jack up the tank. As the tank gets higher, work the electrical connectors back through the hole.
I started the front bolt first and found that to be the best. Just get a few threads started on the front bolt and then work on getting the rear bolts. I found the passenger rear bolt the hardest FYI.
I may come back and add a few things....
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Very good writeup, thanks outdoor. Your rank = "MVS Contributor" and this is now pinned this in the Volvo Repair Database.
Also -> Amazon link
outdoor7or24
matthew1 wrote:Very good writeup, thanks outdoor. Your rank = "MVS Contributor" and this is now pinned this in the Volvo Repair Database.
Sweet! Thx.
I hope this helps out folks and glad I could give back some knowledge on the forum. MVS has helped me!
