Extremely corroded fuel pump connections
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
benhogan
Year and Model: 1992 volvo 240
Post by benhogan »
I atttempted to replace the fuel pump (92 240wagon) this weekend. After removing the cover, I noticed a lot of corrosion on the cap. The connection easily broke off. I tried to turn the cover (hammer and wood method to get it started) to no avail. Very rusty as well.
I plan to make WD40 my new best friend pretty soon. Does anyone have tips on how to get the cap off safely?
Ben
1991 240 Wagon
1992 240 Wagon
1990 Mercedes 350sdl turbodiesel
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
A good soak with WD40 or, if you can get it, Plusgas, similar to WD40 but much more potent. Also try to get a pipe wrench on to it to give better leverage.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
benhogan
Post by benhogan »
billofdurham wrote:A good soak with WD40 or, if you can get it, Plusgas, similar to WD40 but much more potent. Also try to get a pipe wrench on to it to give better leverage.
Bill.
Thanks Bill.
Side question....since the connector on the top has broken off, do you think i now need the whole assembly. I guess I'll figure it out when i get it off.
It's been so cold here recently that it hasn't been fun to work outside
Ben
1991 240 Wagon
1992 240 Wagon
billofdurham
You will need a complete unit as it is unlikely that you will be able to replace the connector.
Bill.
Previously:
