wiper motor swf or electrolux?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
doodle
Year and Model: 1986 760
Post by doodle »
86 volvo 760 turbo with 4 pin connector on harness windshield wiper motor. kragen auto parts is asking if i need swf or electrolux for the cardone motor replacement. nobody knows the difference, do you? thanks
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
VADIS is of no help as the pictures for both motors are identical. However, after a little digging I came across this which may be of some help:
wiper motor - electroluxl.jpg (19.13 KiB) Viewed 1586 times
Electrolux: In addition to markings on the motor itself, later Electrolux manufactured assemblies are also recognizable by the molded black plastic cover which protect the Parkswitch and harness connections, and they typically have a green sleeve protecting the harness running to switch. These are, in my opinion, the nicest design of the three early type wiper motor assemblies I have seen.
wiper motor swf.jpg (31.89 KiB) Viewed 1586 times
SWF: I was not able to find any manufacturers markings on the motor itself, but after cleaning grime away, I finally spotted the manufacturer's definite logo in the maingearbox casting (ringed in yellow). SWF supplied assemblies typically have a black sleeve protecting the harness running to switch.
The above is taken from an article on this site.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
doodle
Post by doodle »
bill, as stated before, i am working on my brother's volvo, but with all the help you give i would be tempted to trade in my ford for a volvo! i am hoping to come to the end of this project this weekend and will let you know how all your and my work has turned out. i ordered the electrolux motor saturday evening hoping the more expensive one would be the correct on (it usually is). thanks again for your help--you are wonderful! dawn
billofdurham
You are welcome, even if you do drive a :shock: Ford :wink: .
Bill.
Previously:
