I had a look at the brakes on our 97 850. There is aprox. 20k on the pads and rotors. The fronts are about 1/2 inch thick yet but the backs are maybe 1/8 inch?????
Any ideas what might cause this?
Braking when driving feels normal, no grabbing or shaking.
The TRACS ABS light is on intermitantly.
Would this be the reason?
850 rear brakes
- misha
- Has thanked: 152 times
- Been thanked: 402 times
The reason for intermittent abs/tracs light could be a faulty abs module.Don't worry...if you know how to solder,it's easy job.90% of mvs members,including me,did that job ourselves.There is a great detail write up on this forum about how to do that,including pictures.
About differences in brake pads wearing....usually,rear set of brake pads needs replacement after every other(every 2nd) front brake pads replacement.Meaning...two sets of front brake pads=one set of rear brake pads.That's is some kind of rule.
So....maybe the front brake pads are allready replaced 2nd time and now,the rear ones needs replacing.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Rich
- Year and Model: 97 850 Awd
Thanks for the info on the ABS module.
The car has 207000km on it about 130000 miles. But like I said we just had the brake pads and rotors replaced 15000 miles ago.
To me that seems a little quick. If thats normal than I guess thats normal.
Thanks for the reply guys.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
That does sound quick...my pads have over 40,000 miles on them, and still have plenty of pad left all the way around. I have no idea what kind they are, they were on there before I bought the car, and aside from squealing under light braking, they work just fine. I haven't exactly been nice to them either.
I wonder if your calipers are sticking. Have you ever flushed your brake system?
'98 S70 T5
2016 Chevy Cruze Premier
Rich
No I have not flushed the system......its on "the list".
I was thinking maybe there is rust bulit up on the caliper where the pads are suposed to slide? Not allowing the to fully relax when released keeping them on just slightly all the time.
Does this sound possible or am I totally out to lunch??
jblackburn
Could be. Or old brake lines. Jack up one side of the car, then put it in neutral WITH THE PARKING BRAKE ON, and try to spin the front wheel. Next, park and turn the parking brake off, and try to spin the rear wheels. They should spin reasonably freely; otherwise, something is sticking. If the caliper itself is sticking, spray some PBlaster around it, grease your slide pins, and the piston itself. Let it soak a while, and give it a couple good whacks with a hammer. That should help them release fully if they're sticking.
'98 S70 T5
Rich
Thanks for the ideas...........I also have 2 other issue that I've been trying to locate answers for here in the forums.
1. Reverse lights.........work sometimes, car is a standard and once in a while they work(very rare). I've tried to "wiggle" and move the shifter in the revesre position but nothing. They only come on when they want and just for a quick flash.
2. Where do we find how to fix our own ABS module?
jblackburn
ABS Module:
https://www.matthewsvolvosite.com/forums ... hp?p=46827
As far as the reverse lights, I'm thinking you have a bad or out-of-place reverse light switch that is depressed and tells the lights to come on when the shifter is moved to that position. Pop the shifter boot off and have a look.
http://www.eeuroparts.com/Main/PartDeta ... id=9442728
^^Here's that part.
^^Here's that part.
'98 S70 T5
- 5196 Views
Last post by vtl
- 1670 Views
Last post by timmybdaddyof3
