740 1990 300,000 miles, Cruise control
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
blackvolvo95
Year and Model: 960 1995
Post by blackvolvo95 »
My cruise control just stopped. It is not the fuse. Are there other easy things to check?
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Further checks on the cruise control can be done using the On-Board Diagnostic (OBD) unit in the engine compartment. Unfortunately, you will have to link the cruise control unit to the OBD using a long jumper wire which you can make up yourself. The test procedure is lengthy but I can post it for you if you wish to go ahead. Some of the later, more complex tests can only be done with a proper Volvo jumper wire.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
blackvolvo95
If you can post the instructions, I will try and do it. Thank you.
billofdurham
740 Cruise Control.pdf
(2.3 MiB) Downloaded 404 times
Bear in mind that this is intended for experienced mechanics so some of the info won't be of much use. I suggest that you read page 11 first. There you will find the instructions for conducting the initial test. It is important that this is done after a run in which the car exceeds 22mph and the ignition is not switched off before interrogating the diagnostic unit.
Bill.
Previously:
blackvolvo95
I have tried numerous times to download this file, and Adobe tells me it is damaged. Would it be possible to repost the file?
Thanks much.
blackvolvo95
I was just able to open this file from another computer, so no need to post another copy. Thanks anyway.
